Could someone please tell me what the part in the photo is?
It came from Parts Tree B from the Hornet Evo kit, but it had no indication in the instructions on where it goes or what the part is used for.
This is from the hornet evo instructions.
Looks like the B3 part has been replaced by the part marked E3 and a ball bearing.
20 minutes ago, RC_Hobbyist said:
Is this an adapter so you can use 12mm wheels instead of tamiya wheels?
No, it's just an extra part. That happens quite often in Tamiya kits, that reuse parts of another chassis. The manual shows parts that aren't used in the build.
Hornet uses different wheel axle than DT-02/3. You'd need the DT02/3 axle to use 12mm wheels.
Didn't realize the parts marked in grey were not used.
Thanks for pointing it out.
Urm, guessing you might be able to, not Tamiyas intention though, just cheaper to give you a part you don't need, than make new moulds.
Better to have it and not need it rather than need it and not have it ;)
