Sorry if this has been asked before, but is there any listing for Tamiya suspension shaft lengths? I'm not particularly happy with the slop in my Hornet Evo's front inner arm mounts (the design causes a similar issue to that of the upper front arm mounts on the Hotshot series). Real shafts with e-clips (at the proper length) might allow for me to make a bridge tying the two together and cutting down on slop.
I don't have a definitive list, but I know a few off the top of my head
22mm (DT03 kit)
25.3mm (DF01/top force front)
33.3mm (DF01/Top Force rear)
38mm (TL01/M03/M05 outer arms)
48.5mm (TL01/M03/M05 inner arms)
58.5mm (M05 front inner arms)
X
Most touring cars are 46mm
TA04R 48.5mm
TA08/XV02RS 43mm
TA05 49.7mm
TB evolution III/TB02R 51.3mm
TT01E 38mm
There are more but all the above are plain shafts without E clips
Not a great use without the clips but you could put them in a lathe and cut a groove for them!?
With E clips
TA02 48.5mm + 33.4mm + 25.3mm
TA03 41mm + 30mm +23.5mm
TB evolution 45mm + 28mm
These are what I bought to use, although I've not bought the kit yet. There may not be enough to add a brace though.
https://ttpmodels.com/products/tamiya-9804360-19804360-3x41mm-shaft-2-pcs-nitrage-trf502x-db02-trf102-nip?srsltid=AfmBOooGW39p7mwnT94W8RzL1MG4nFXxinF9HUcAbdeJ0B09I2lP8QUz
