I would expect they are for the standard hornet adapters given that they’re being sold by Tamiya for hornets.
That said, if the inside face has a hexagonal recess then they are for hex adapters.
a photograph of the inside face would help.
I'll double-check when I get home, but I'm pretty sure they are meant to fit the new Hornet clamp on hubs.
https://www.tamiyausa.com/shop/option-parts/rc-hornet-aluminum-wheel-hubs/
Terry
ETA:  if they are 12mm hex drive, you can use a set of adapters like these:
https://www.tamiyausa.com/shop/option-parts/rc-pin-type-wheel-adapter-set/
or these:
https://www.tamiyausa.com/shop/option-parts/rc-clamp-type-alu-wheel-hub/
Based on the photo below, it looks like they take the cylindrcal adapters, which I already have on the rear axle, as I bought a set of star dish wheels.
As a side note, the front wheels have two round openings for the bearings.
Those wheels fit with no special adapters needed, just the standard 5 point hubs that came with the hornet/grasshopper, ORV buggies, SRB's and CW-01 platforms.
3 hours ago, Frog Jumper said:
As an aside, these wheels do not take dye, and need to be painted (if you don't want white).
Terry
I don't mind the white, especially since I am trying as much as possible to keep it to the original
The set I tried to dye ended up a puke brown color, so I sprayed them with primer and some kind of Tamiya TS silver (glossy aluminum???).
Terry
2 hours ago, RC_Hobbyist said:
How did that turn out?
The Tourque Tuned?  It's a really nice upgrade from the standard silver can.  The TT with a 19T pinion vs. the stock silver can with a 17T is a great cheap upgrade to the EVO.  It isn't life changing but I would say a nice 15-20% increase which makes the EVO feel really fun to drive.
I mean it isn't one of my TLRs or my Schumacher etc. but for driveway fun......the EVO with a TT is awesome on 2S.
