I run an Avante Black Special.  Lipo plus the brushed motor in the kit. No hop ups are necessary.  Just be aware that the battery compartment can only fit one of those rounded NiMH-shaped Lipo's by default and would require some inguinuity to take a shorty or squared-off battery.  I'm not aware of any aftermarket parts to make this easier.
Mine has VQS Hi-cap dampers which requires a shock mount such as Nick Walker sells. Beyond that is only replacing stuff as it breaks or wears out.
I have bought the parts to upgrade the steering on my Avante 2011 to the racing steering that comes with the Avante Black Special. I have no real idea if that is beneficial or not so it might just be a waste of money. The racing steering set doesn't seem to be available any more, but you can get all the spare parts separately and build it up yourself - it just works out a bit expensive.
As Twinfan says, expect fees on entry to the UK (and a delay whilst Parcelforce uses their antiquated system of sending the VAT bill through the post before they will deliver), but it will still work out significantly cheaper than buying from a UK shop.
5 hours ago, Twinfan said:
Charges will be 20% VAT plus a £12 handling fee, so around £72 to pay.
Doh! 🤦‍♂️🤣
Although it's DHL rather than Parcelfarce, I'm guessing there'd be a brexit charge..
Posted (edited)
41 minutes ago, Wooders28 said:
Doh! 🤦‍♂️🤣
I suspect it'll be DHL in Europe and handed over to Parcelforce in the UK. No idea why.
One thing you do need to know about running an Avante is that you have to threadlock every metal-on-metal connection. Every single one. Yes, even the upper arms. Make sure you don't get any in the rose joint balls though. The Tamiya rose joints are super pricey,  but it's easier to get aftermarket ones these days with them being common on crawlers.
Edited by naturbo2000
I think i's because DHL is the regular postal service in Germany, not just a courier like it is here in the UK.  So it gets handed from local postal company to local postal company.
I highly recommend brushless, the maintenance free aspect alone sells itself.  A 13.5 hobbywing would make it fly. I wouldn't go lipo as the current stick form lipos are a hair too big. For upgrades id just add metal front and rear hubs for peace of mind.  That said I have a first run Rere Egress and I've yet to brake anything on it.
I now proactively shop only with companies that give me the option to not use Parcelforce. Truly shocking service and so expensive.
Think the slowest I've got, is an 8.5t...🫣
Probably go for the new 10BL120 G2, although I've an old LRP flow kicking about somewhere ...
The Corerc CR293 I've got, has fitted everywhere the old Nicad/Nimh fitted, so that's should fit, or it's going to be made to fit 🙄
Didn't realise DHL turned into Parcelfarce this end, I'd have gone for the more expensive (but cheaper...), option!!!
(Hope they remember to post me out the ransom letter, they forgot on an order from the States, and only me trying to chase it up, and driving an hour to the depot, stopped it getting sent back...🤦‍♂️
Edit,
Dug out my motor options....urm
20250302_152802
1 hour ago, Kpowell911 said:
@Wooders28 Has yours arrived yet?
Letter from Parcelfarce still hasn't arrived with the info, but phoned them with the tracking number I got from Tamico (the German tracking swaps to a GB one) they gave me their customs tracking number, so then been online and paid the £70 ransom (pretty bang on @Twinfan !!).
Should arrive in the next pay or 2..
Looking at putting an order in for paint, esc (probably a 10.5t motor..) etc and presuming Tamiya provide their usual aluminium / soft cheese pinion with the kit?
Seen another thread, and seemingly the pinion options are 06mod, 12 - 23T ?
I can't imagine the low tooth pinions are required with modern motors, so thinking of maybe a 17, 19, 21 and a 23t should cover all track configurations? (Tight twisty carpet track, to wide open with long straight Astro tracks?).
So this is going be raced? Very interested to see how that goes.
Nothing serious, will just be vintage races probably.
Thinking of tungsten carbide balls for the centre diff (always thought that was a slipper 🤦‍♂️) and then just play about with set up/ shock oils/ springs (got a set of springs for the mid that I'm hoping will fit) and gears.
Presuming they're 2" tyres too, so the Schumacher blocks/mini spike and full spike will fit..maybe
Mine gets raced. It's a terrible race car,  but can be elevated to bad on the right surface. It's hard to tune. Even changing batteries is a chore. Definitely threadlock everything, especially the upper suspension arms. It doesn't appreciate being crashed and takes a bunch of time to repair breakages.
And yet I still race it on a small, indoor, polished wooden floor and absolutely love it! :wub:
This week's task is to replace the upper deck on mine as I broke it at the left hand trailing arm hanger.  Nick Walker does a chassis brace which is going on my replacement chassis.
  • Thanks 2
Used to beat them regularly with my Mid bitd, but they are a stunning bit of kit, too nice to just leave on a shelf..
Oh dear, I can hear my wallet shaking with fear at the mention of his name...🙈🤣🤣
