The last one I had, the setup procedure was;
i) Connect battery
B) Press and hold 'setup button' within 5-10 seconds, until forward LED flashes - Push stick forward 'til LED stops flashing
3) Pull stick back when reverse LED flashes until it stays on, then press 'setup' button to finish off
The main trouble I had to start with was that the three wires on the plugs to the receiver and servo (Acoms) were in the wrong configuration to the speedo, so they had to be juggled (phone m-sonik if need be, they're dead helpful)
If you mean the new Carson M-sonik ESC it is as explained below just you need to press the set up button each time you reach each positition (full and full reverse), otherwise the ESC cant konw its reached, one touch means one button not one press.
