I bought a set of TT-02 CVA Super-Mini Shock for my Toyota Gazoo Racing WRT TT-02.
My question is does it matter which way around you put the shocks on the chassis (IE Front on the rear and vice versa)?
Since they are all the same length, I would assume it doesn't matter (But I have been taught to never assume anything ;)).
When I was building my Hornet Evo, the rear shocks were longer than the front shocks, so it was obvious where they went.
If all the same size, it does not matter. It's the rest of the shock setup that matters, like what pistons and oil you are using, or maybe you want to run different springs in front than the rear.
Straight from set, all are exactly the same. Build them stock and then adjust if needed.
