These are parts I've accumulated over the last 5 years. These were either for projects that have now been moved on, or were bought on a whim. Prices include UK shipping. Happy to do a deal on multiple items..
Egress 2013 kit. Unbuilt. £375 or £450 with the Xtra Speed parts below.
Egress 2013
Xtra Speed aluminium parts for Egress. £90 £80
20250804_152717
Kyosho Turbo Scorpion 2.2 Black Front & Rear wheels x4 £15 each set
Kyosho Turbo Scorpion 2.2 White Front & Rear wheels £15
Kyosho Turbo Scorpion 2.2 White Front & Rear wheels with tyres, (not glued) £SOLD
20250804_143943
2x 54797 Touring car short spring Set £14 £12 for both
53861 Camber gauge £6 £5
74163 Mini 4WD cleaning brush £4 £3
74121 Craft tools mini 4WD (+) JIS screwdriver pro £4 £3
2x 53850 TRF damper titanium coated piston rod £10 £8 for both
54922 Adjustable suspension mount bushing £4 £3
51749 XM-01 D Parts (Suspension Arms) £5 £4
54894 TBLM 17.5t motor, new. £50 £45
20250907_215943
2x 54465 XV-01 dirt spring set (No silver springs included) £10 £8
20250622_153638
22049 XV02/TT02 oil filled gear diff x2  £25 £20 each
22074 XV-02RS stabiliser kit  £SOLD
22055 XV-02 adjustable suspension mounts x2  £12 £10 each
42245 TRF adjustable body mount adjuster x2  £12 £10 each
22048 XV-02 slipper clutch £25 £20
22076 XV-02 Short Damper Stay Set £25 £20
54607221140_ae5274b2da_b
42221 Cross Joint for Double Cardan Joint Shaft x2 £5 £4 each
22054 37mm Drive Shafts Double Cardan Joint Shafts £15 £12
42219 Joint Casing for Double Cardan Joint Shaft £10 £8
53500 Cross Joints for Assembly Universal Shaft Set £5 £4
51444 Cross Joint Set TRF417 x2 £5 £4 each
20250622_153229
I just have to say that the Mini 4WD Grasshopper Jr is very nice - takes place of pride on our living room piano. :)
Massive Thank You to Neil for the TRF stand and the Avante Jr's! All arrived very quickly and very well packaged! This guy is a LEGEND!!!
  • toyolien changed the title to Loads for sale. All sorts.
  • toyolien changed the title to Egress Parts, Kyosho Scorpion Parts, Motors and all sorts.
  • toyolien changed the title to TRF Parts, Kyosho Scorpion Parts, Motors and all sorts.
Just adding thanks for sending the Stands & Le Mans motor - these have arrived very carefully packed & has been a pleasure - thank you again!
  • toyolien changed the title to Egress 2013 Kit & Parts, XV-02 Parts, Kyosho Turbo Scorpion Wheels & More
