TexVan Posted June 10 Posted June 10 Years ago, I wanted to change the motor on my Wild Willy 2, but 2 of the screws holding the motor on are completely stripped. I went to multiple hobby shops and they couldn't get them out. I tried extractor screws...I feel like I tried everything, but I couldn't get those screws out -- I'm open to suggestions. Ha ha. And since I couldn't remove the screws, I couldn't take the gearbox apart either. So recently, I decided I wanted to get the car running again, and I just want to get a new gearbox. I've searched the net and can't find one. I don't need the entire chassis, the wheels, or anything else...just the gearbox. Is it possible to buy just the gearbox to a WR-02 chassis?
JimBear Posted June 10 Posted June 10 @TexVan Yep, you can buy the whole kaboodle with motor, parts number 18085153. Or the gearbox housing, TA-10005713. 1
Guest Posted June 10 Posted June 10 1 hour ago, TexVan said: Years ago, I wanted to change the motor on my Wild Willy 2, but 2 of the screws holding the motor on are completely stripped. I went to multiple hobby shops and they couldn't get them out. I tried extractor screws...I feel like I tried everything, but I couldn't get those screws out -- I'm open to suggestions. Ha ha. And since I couldn't remove the screws, I couldn't take the gearbox apart either. So recently, I decided I wanted to get the car running again, and I just want to get a new gearbox. I've searched the net and can't find one. I don't need the entire chassis, the wheels, or anything else...just the gearbox. Is it possible to buy just the gearbox to a WR-02 chassis? Have you tried using a Dremel on the head of the screw? Just grind enough out so you can get a flat head screwdriver in there and extract it.
TexVan Posted June 10 Author Posted June 10 @JimBear Thanks! @Gorgonzola I don't own a Dremel tool, but it might be time to invest in one. As for the stripped screws, its like a smooth concave divot. There is little to no surface information for an extractor screw, or anything else to grab onto at this point. I've never encountered a screw this stubborn. 1
Guest Posted June 10 Posted June 10 30 minutes ago, TexVan said: @JimBear Thanks! @Gorgonzola I don't own a Dremel tool, but it might be time to invest in one. As for the stripped screws, its like a smooth concave divot. There is little to no surface information for an extractor screw, or anything else to grab onto at this point. I've never encountered a screw this stubborn. Just buy a cheaper one buddy. I bought one of Ebay for 30 quid and it's superb. It lasted way longer than a genuine dremel. You might have to drill into what's left of the screw and try extracting it that way. Are they hex head screws?
Guest Posted June 10 Posted June 10 12 minutes ago, TexVan said: @Gorgonzola It's just a regular phillips head screw. The drill and extract method might be your best option. There's bound to be some videos on YouTube showing how to do it.
Twinfan Posted June 10 Posted June 10 Given the fact you can buy a replacement gearbox for about £30 I don't think it's worth the bother of Dremels etc if you don't already have one! I'd just buy a new 'box, then hack the old one's casing about to salvage a few spare parts for the future.
TexVan Posted June 10 Author Posted June 10 @Twinfan Yeah, I don't think I'm going to run out and buy a Dremel set right away, but it is a versatile tool, and I have run into a few situations where having one would be handy. For now, I may just order a new gearbox. A Dremel would probably help cracking open the old one though. Ha ha 1
MadAnt Posted June 10 Posted June 10 Just drill the screw heads off and yank the motor out. Simple job, don't waste a whole gearbox. 3
Thommo Posted June 10 Posted June 10 3mm screws only need a 3mm drill bit if you can centre it. Might avoid the plastic completely with a steady hand. 1
TexVan Posted June 10 Author Posted June 10 Like I said, I've tried drilling them out, several hobby shops have tried getting them out, I've tried extractors...they are really stuck in there.
MadAnt Posted June 11 Posted June 11 5 hours ago, TexVan said: @MadAnt Here's what it looks like. Drill it until the heads break off. I have no clue how you messed this up unless you used the wrong type of driver or tools. How do the rest of the gearbox screws look? 1
TexVan Posted June 11 Author Posted June 11 2 minutes ago, MadAnt said: Drill it until the heads break off. I have no clue how you messed this up unless you used the wrong type of driver or tools. How do the rest of the gearbox screws look? Ha ha ha, I don't either. The rest of the screws are perfectly fine.
RichieRich Posted June 11 Posted June 11 That is impressive. I don’t think I’ve ever seen that before. There must be thread lock involved because over tightening surely would have cracked the gearbox.
Register a new accountSign in
