Hey Lads,
I need some help from someone out there to solve my gearing problem on my homemade crawler. It uses a SC gearbox and the gearing is to fast for crawling. What I am really looking for is possibly some sort of planetary gear setup that would go inline with the motor. I have looked into the high torque low rmp motors but I don't feel this is what I want, I have also looked into cutting custom gears for the SC gearbox but with the limited distance between motor and input shaft I could really only fit a pinion with one or two teeth less.[B)]
I once saw a two speed system on RC4WD that looked like it might be my answer but they no longer carry it.[:(]
I also do not want to do away with the gearbox, it it very unique to my frame.[;)]
Thanks,
Mike.
I don't know if it will give you enough reduction, but what about a 1/14 3 speed gear box. I seem to recall somewhere on RC4wd photos of one set up with a transfer box, maybe you could mate it to your SC gearbox? just a thought.
Mike.
This is the beauty of this site and these forums, in one day I got three different suggestions for my problem.[:P]
I will figure out what I will do and definitly let the public know.
Thanks for the links.
Mike.
Taken the plunge on some kit, for a forthcoming TLT project [:D]
40 turn motor
3.8:1 inline gearbox
Spoke to a chap at http://www.fanfare.f9.co.uk/ who was well helpful on it all; the gearboxes are designed for airplane props, and although he'd not heard of crawlers, wasn't too dismissive of the idea [:D]
The thinking is to run a pinion off the end of the gearbox pictured above, then use that to turn a spur.
Current TLT gearbox produces 8:1 (nearly) so a regular pinion and spur combo will easily result in 8:1+
  • 10 months later...
Well this took a long time, I finally found a uS distributor that sells the same gearbox that Twinset got. It costs $30usd and I have one on the way.[:D]
Can't wait to mount it on my Silverado TXT.
Thanks to Twinset for putting up photos of this unit I needed those to locate it.[:X]
Mike
Alot of crawlers use the GD-600 from Great Planes. The output shaft is 5mm, so it'd need to be machined to the standard 3.2mm for standard pinions. Redux from 2.5-3.8:1.
Yes I have seen the GD-600, it is much more common. What I like about this unit is that its inline design makes it very compact for special applications where space is at a premium. However it would be nice to be able to adjust the ratio.
