i've got an XB. have fitted an Mtroniks Eco27 esc and an LRP 80 turn truck puller motor. now waiting for G-parts to arrive so i can try it out.[:D][:D]
you simply place your hand firmly beneath the front of the truck, and pull upwards, Lol[:P]!
Seriously now, im not sure much can be done. you could machine out the carrier hubs to stop the driveshafts rubbing on them, but too much would make them weak and liable to break. You dont really need to mod this truck much, my touareg is pretty much standard and its v.good off road.
hope you have fun with your pajero,
James
  • 2 months later...
a dremel taken to the front hub carriers,and the inner edges of the arms(not too much,just enough to allow droop)will net you about a 1/4" more droop. then add a set of short buggy front shocks.(i use a set of duratrax evader buggy,threaded front shocks).then,use traxxas T-E-maxx tie rods(105MM long rods on the lower links,and 95MM rods on the top links)for stronger 4-link bars in the rear.i then mount another set of the buggy shocks(or 4" shocks)i run the lower shock mounts slid over the rear most threaded end of the bottom link-rod(shock runs in front of the axle)and this allows for tons of articulation.lastly an ESP driveshaft extension(used on the juggernaut long chassis kit)and your set for some serious offroad action. hope this helps.
