Hi all. I want to put an ESC in my Bruiser. I want to harness the variable power avialable with an ESC. It would need to handle the 750 motor and be able to take a varity of power cells from 6v 8000mah to 14.4v 2 x 7.2v 2400mah packs. Which one do i get as i have only ever used a tamiya BEU 101 TK and that is in my Lunch Box and Hornet. Thanksid="blue">
Wouldn't recommend running the Bruiser on more then 7.2V as its motor and most important the whole transmission wouldn't handle it for long. With the stock 750 motor and 7.2V you can use even the cheapest ESC, also the BEU 101 should handle it with no problem.
