Just a quickie, need the outer diameter of a standard TLT rim, and also the diameter of the tyre.
Same for a 2.2 truck tire would be great
Just doing some layouts [;)]
id="quote">id="quote">
According to Tower...
OD for 2.2" Dirt Hawgs is 4", which is about 102mm in real money. Their measurements for the TLT tyres are a bit confusing but seem to say 89mm OD which seems about right. Which diameter do you want for the TLT wheel as they are 'offset' - inner (hex side) is different to outer. I can measure them tonight if someone else hasn't already done it. HTH. David
he he
Sorry David, it wasn't that technical, I just wanted to slap wheels n tyres on a coupla cad drawings last nite.
As it is, I got all my bits here at work, so I can measure them meself now - I wanted an answer last nite, where were you then eh?? [;)]
The real daft thing is, I dont even have TLT wheels, I meant WW2!
If anyone needs it, ww2 rims are 55mm od, and the tyres about 110mm
HPI 2.2" wheel has outer bead diameter of about 60mm, Masher 2K tyre OD is 125mm
Info to the whereabouts of my 4th WW2 wheel and tyre would be appreciated [:(!]
quote:
Originally posted by MadMax
it's on that shelf to the left by that sheep of paper[:o)][:o)][B)]
Pah! I scoff at your rubbish spelling and keyboard skills [:P]
just a quick question will hpi mt2 rims fit the tlt-1 with the geolander tyres on or would they rub on the hubs
thanks
Virus
thanks
Virus
I have seen a few people run this set up so I think they would clear with no problems. the only rims I haer about rubbing are the stampeed wheels
