Here's how to make one (cos someone else asked)
Get yourself a printer, some scissors and a self adhesive address label or four.
Print out the pic below, resizing it until the holes are about 48mm apart.
Once you got it the right size, print it again on the address label.
Cut off the section of uNDER the dotted line - this is to represent the thickness of the alu angle.
The vertical line on the left, is a marker for cutting the 'bottom' section - see pics;
Cut around shape, and also cut bottom 'lip' to 8mm from vertical face
Drill and countersink servo mount holes (3.1mm or 1/8 diameter hole);
The shape on the left hand end may need a bit of fettling, to get a tight fit to gearbox
Shape of gearbox end may need a bit of fettling to get tight fit
Tight fit - hence the countersink :)
Line up, then mark for drilling the fixing holes
3.1mm or 1/8 diameter again
