I had been search the web for a few day but still unable to find a after market oil shock to replace the stock coil spring[:(].And i know is almost impossible to find the #50305 shock.Can some kind soul direct in to purchase the shock.A link to the web will be good.
monster beetle ones seem to be exactly the same, well they fit perfectly anyway! maybe try purchasing a wrecked monster beetle just for the springs? i saw a set of 4 shocks sell recently for £20, a little while after i bought a hole monster beetle chassis for just over £20, which had the exact same oil shocks fitted!
other tamiyas use the same oil shocks so take a good look and you mite find some.
quote:Originally posted by theshopkeeper
Code has changed as the bodies changed from yellow to black, current code is 50520 C.V.A. Short Shock II £19.99
id="quote">id="quote">
So this 50520 is exactly the same as 50305 only for the change of colour of the shock body?This mean i can fit the shock into my MP without modification,right?I am not good with doing mod to R/C.You reply really help me alot.
quote:Originally posted by jozza
It's the same item, the instructions mention the Midnight Pumpkin and which spacers you need to fit for the MP. You will need the little u shaped metal brackets that came with the Pumpkin to fit them.
See http://www.cosmic-cat.co.uk/images/rccars/...ck_Box_Rear.jpg for a scan of the box. (Option 4 is for the Pumpkin)
Really a big thank for your help.A picture really worth more than a thousand words.[:)]
