My Touareg is going well as a crawler- locked diff, truck puller and so on, but I want a truck body for it.
I have seen the Clod body on some in the showroom, but to get one new is expensive. I suppose the Parma lexan copy will fit. How good is it?
Has anyone fitted any others? The best truck/Jeep bodies by HPI/Proline look waaay too big to me, is that correct?
Thanks for your help. [:D]
What about Proline bodies for the Stampede? It has the same wheelbase, but not sure about the width?
I suppose it is possible to cut the propshaft to fit the SWB layout. Could cut a bit out of the middle and stick the ends together in a hollow shaft. Would then be possible to use for either WB.
What about a Blackfoot body? I just finished this swap and it was pretty easy. The Blackfoot Extreme body is way cheaper that Clod body. I want to say something like $30 for body set on Tower. I've got mine posted in my showroom if you want a look at how I did it.
