CAN ANYONE HELP ME PLEASE. NEW TO RC CARS JUST GOT A TWIN DETONATOR, HOPING TO FIT SOME HOP uP PARTS BUT DO NOT NOW WHAT TO FIT. THANKS
Think you want to be posting in the monster truck section not meetings and events for this query. Turning off the caps lock would be nice as well [:)]
Hi Ady30, for brg's just ask your lhs for a TL01 brg set. For motors you have loads of choices, but first you'd have to replace the msc to a decent esc, I'd recommend an LRP F1 PRO reverse as that is what I'v got fitted to my (up forsale) Wild Dagger, same chassis, with 17x1turn Peak Racing Jaguar motors. To wire up the esc to work with 2 motors just cut the msc wiring and crimp on some appropiate bullet connectors. For the shocks either 60/70mm Carson ones will fit nicely, DON'T fit the Tamiya hop-up option units there to short. Have fun.
For more info into this vehicle click onto the link www.rcdaggerweb.com, this site is a goldmine of information.
Thanks Adamski for your help, I have alot of things to look into.I think i will start with the brg set thanks again[:D]
Definitely start with bearings. Once you've done that, grab some oil shocks, you can use standard Tamiya ones, or you might want to make a shock tower to fit longer shocks. Personally I'm happy with standard length shocks. For motors, Kyosho Magnetic Mayhems are the most popular, but have been discontinued. You might want to try a pair of Graupner 600's.
Speedo, anything which will handle 2 motors in parallel, be careful here as it's easy to blow an ESC if it's not capable. Search in the forums, take a look in my showroom for detailed instructions on wiring up a speedo to twin motors.
I've also replaced the pinion gears in my Dagger with the 21T, but it doesn't make a massive difference, slightly faster top speed.
id="quote">id="quote">
Are you sure they're not 20T? The gearboxes just have the alternatives of 18T or 20T pinions unless you modify the gearboxes or mount an adapter between the motors and the gearboxes.
id="quote">id="quote">Well spotted, I meant 20T [:I]
quote:Originally posted by Hazy75
quote:Originally posted by Wild_Trial
You mean my main chassi?????
Yes,the main
Home made,by some drawing's we have on the daggerweb site.
