Hello all, i have some mad things in my head using alloy but im wondering if 2 parts can be joined together????? Is there some sort of solder on the market or can they only be welded???? if so what sort of welda would i need????
Many thanks
TAZ
Lets say i had some tubing that you buy in somewhere like Homebase wanted to make a roll bar or something
dose that help??????
Hay All
yeah im talking about aluminium tubing, would i need to buy anything to braze it with???? Any idea where i can get gorila glue from???
Thanks for your time everyone
A GOOD blow torch, a standard one won't do the trick!!
Aluminium is a pig to braze/weld well!!
Have you thought about brass tubing??
Normal blow torch and SILVER solder is good for this
And by silver solder i mean proper silver solder not the normal plumbing stuff
i wont get to technical but aluminium can only be either TIG welded, or MIG welded, gas welding it simply does not work well at all, you end up with a puddle of contaminated ally, or very poor joints.
it is an absolute pig to weld because of its low melting point.
for a top job, TIG welding is the way to go, but it doesnt come cheep, and its not easy, especially with thin materials.
a mig welding plant thats capable of aluminium welding doesnt come cheep either, the model i use at college for aluminium welding cost over £6000 [xx(], and the tutors dont know how to work it lol [:o)]
fatboyslims idea of using brass tubing would get the job done perfectly, and is far more achievable using d.i.y tools [:D]
thanks to everyone who has given advice towards this and maybe i will go with the brass pipeing idea as its will be cheaper.
