Hello,
I was wondering if there's a good type of glue to use when resticking corners of lifting decals? There's some grit where the adhesive is, is there something good for removing that without damaging the decal?
Thanks,
- James
Testor's produces something called 'decal set' that is used to put the edges down permanantly. I have also seen clear fingernail polish recommended.
As for grit you may want to try alcohol.
Cheers,
Hi
First are they waterslide or sticky stuff decals by the looks they are sticky stuff decals i would try some lighter fluid and then use some spray adhesive you can get it at your local frilly kind of hobby shop (craft store) but if they are waterslide i would use Elmers white glue as it dries clear.... so there is my 2 cents worth hope this helps you out[;)]
