Hi i just got the VW touareg like 5 days ago and loved it so much i got myself a pajero XB now also!
? i need to ask is the pagero has no oil shocks it has friction jobbers.. you can see the body sway back and forth when turning .. thing is when i was crawling with it the suspensin worked better than my touareg with it's oil shocks??
the pajero you can see it flex the suspension when going through stuff and the touareg lifts its wheels off the ground when you do the same thing...
Well the big ? i am getting at is does thinner lighter wieght oils work better for crawling and trail running?
Thinking 10WT maybe 15WT?
Any info will be GREAT
Yes, for crawling you need soft springs and oil, although at most crawl speeds (= really slow) dampers play almost no role as damping force is proportional to suspension speed movement and when that is low the damping force is close to zero.
hi shenlonco I have also just recieved ( 2 huors ago!!! )my xc is a lowrider isuzu mu to be exact! Looks good now i only need to drive it though![:D]
