Always liked that bod, so thought I'd do something similar for the racing Clod
Got an old Parma Mustang, and got busy
It was a bit of a half-hearted job really, I lost the
decal sheet a while back, and the outside of the shell
is quite scratched, but here's the start to finish [:D]
First off, thouroughly wash the shell and dry it well,
just to remove fingerprints, mould release and grease from the inside
Find a mould line on the shell, that crosses another, to use as a start point
for the masking tape
Then, find an end point
Tape a strip of masking tape from one point to the other
(on the outside)
So it goes from here
To here
On the inside, lay down more tape, using the strips on the outside as a guide
I find it easier to do this way than to try to get a symmetrical pattern just by laying tape on the inside
Make sure the tape is right into the corners
The handle of a scalpel works great for this, as does a teaspoon handle
Find a second mould line intersection, and repeat procedure as above, tapering the masking to a point
Tape off from the rear, using the same method
Trim excess tape off, for later
Slap a liberal dose of liquid mask over the bits you want yellow
I use Bob Dively's, thankfully, they've improved the aroma[:D]
It comes off easier when thick, and I always scrape the
brush along the edges of the shell,
just to build it up there too
(It dries clear)
Cover the body post holes from the outside, using the excess tape from earlier
This stops any paint going out thru the holes, onto the outside of the bod
If the shell doesn't have an overspray film, mask around perimeter
Then, tape a bin-liner or similar to the masking tape, making sure every part of the bag's edge is sealed
(to stop overspray getting in)
Set up a spray booth [;)]
Give the shell a light coating of black
Dark colours first, so as not to 'shade' the lighter ones
And if it all goes wrong at this point, you can spray the
whole shell black and skip the rest
(Done that before now)
Sun-dry it, or use a hot air gun, but not so hot as to melt the vinyl window masks
(Done that before too [:I])
Whist it's drying, make a coffee and photograph bugs [8D]
If you put the liquid mask on thick enough, it'll come off in one big sheet
Here's some I peeled off earlier
Make sure you get it all, tends to build up around holes
Now the fun bit, finding the screw ups [:(]
Didn't spray far enough up the bonnet/hood
Remasked that area
And painted a bit more black on
Not great, but it'll do
Timelapse piccie time;
Yellow coat next, followed by a white coat to brighten the yellow
Backed with black so it looks good thru the windows [;)]
Big peel-off time
This must be my favourite part of painting, removing the overspray film, and see a nice shiny paintjob
Wish I'd started with a better shell now
Pick out where to put the decals [;)]
Bit of black 'dust' must have fallen off the mask
Good idea to wash or blow out shell between colours
Tiny, tiny bleed, hardly worth bothering with
Eeeesh, big decal needed
Choices, choices, choices
Use a 70/30 water/dish-soap solution, to allow decals to slide a bit once placed, especially long or big decals
Once decal is applied, squeegee liquid out with fat thumb
Made the 70/30 bit up, just runny soapy liquid is fine
Slap 'em on everywhere, being careful to cover the bad bits [;)]
Grill decal is a bit of silver trim decal from a Stadium Blitzer sheet I had kicking around
Headlights are off a Savage sheet
Bad bits covered nicely
And the good bits given the treatment too
Closeup of the 'grill'
And some posers [:D]
All I gotta do now is fit the lectrics and run it into a tree [8D]
Twinset, That is a cracking guide, would you, or anyone else, have any objections (Chris..?) if I took this and stuck it all into a PDF.
Work out details a bit later when proofs are out of it?
quote:
Originally posted by jozza
Is your spray booth available for hire?
id="quote">id="quote">
No mate, the kevlar impregnated sheeting cost an absolute fortune - thankfully I got the last two they had - how lucky was that [:D]
quote:
Originally posted by DCLXVI
How cool, the last picture is a Swedish MT ;)
Yup, took some finding too [;)]
quote:
Originally posted by Tinno
Twinset, would you, have any objections if I took this and stuck it all into a PDF
Nope, press on [:D]
