Sign in to follow this
Truck Stop
Nitro Engine running.
The hints and tips below will help you get best
performance and reliability from your engine.
Running - In
The modern model car engine requires relatively little
running in,due to the use of an abc piston and liner
assembly. The engine should be run quite rich for
approximately 6-8 tanks of fuel with another 6-8 at a
slightly less rich setting.Once this period has been
completed a normal run setting can be used.
A fuel such as 10% duraglow or qwikfire should be
used while running in.
The best methods of checking on the running
setting of the engines, is to first check the smoke
trail coming out of the exhaust when the car is
driving.
A very rich setting would allow the car to pull
away slowly with a momentary hesitation and
lots of smoke from a standing start.
To lean out the engine settings (turning the main fuel
control needle in, in a clockwise direction) will allow
the car to pull away faster and more cleanly
(without hesitation) and increase the top speed.
There should however still be a noticeable smoke trail.
If the fuel control needle is screwed in too far thus
allowing the engine to run too lean, there will be very
little or no smoke trail and over heating and engine
damage will occur.
Fuel and glow plugs
The engine is a 2-stroke design, requiring the engine's
lubrication to be carried in the fuel. Although there
are many fuels on the market for model engines, very
few are designed to perform and protect your engine at
the likes of 35,000rpm that some of our engines can
attain. We recommend only duraglow and qwikfire.
We suggest that for general use, 10% nitromethane
content is the norm, but for the real speed freaks 16%
nitro is awesome!
The glow plug in your engine plays a big part in not only
the engines running but also in the starting characteristics.
Often if an engine is "playing up" or not wanting to start,
changing the plug is a good idea. At the high RPM
that engines operate only a top quality car plug will cut the
mustard.
Please remember a glow clip needs 14 -16 hours charge
before use, it may make the plug glow when it comes out
of the packet but it wont have enough charge in to work in
the engine don't try to put it on for a few hours and then try
this is the most common mistake and most new cars get
damaged this way.
Pull starter Hints
The pull starter as fitted to most of the entry level engines
is if treated correctly, the easiest and most cost effective
methods of starting the engine. As with every silver lining,
there is a cloud. The pull start system is similar to that of a
lawn mower to look at but that is where the similarity ends.
The pull starter is susceptible to breaking if the engine is
flooded or not lubricated enough. To ensure this dose not
happen, a few simple rules should be followed.
1. Before attempting to start the engine from cold,
remove the plug and then prime the engine with
fuel.
For cars with a primer button on the tank, press
this until the fuel has traveled along the fuel pipe
to the carburetor and then a further 5 -10 presses.
For cars without a primer button on the fuel tank,
pull the pull starter rapidly with your finger over
the exhaust pipe outlet until the fuel has traveled to
the carb. And then a further 5 -10 times to lube the
engine.
2.Turn the car up side down and pull the pull
starter rapidly until all the excess fuel has emptied
onto the floor through the plug hole. Re fit the plug
ensuring the copper gasket is also re fitted.
Wind it all the way in and then unwind 1 to 1.5 turns.
This allows gases to escape thus lowering the engines
initial compression.
3. Start engine. The engine will run "lumpily" or stop
after a few seconds, so try to keep it running by
blip ping the throttle. Tighten the plug while the
engine is running if possible. If the engine has
stalled restart with the plug tightened, the above
procedure should always be followed from cold or
if difficulty with starting is being experienced.
Flooding The Engine
The most common cause of engine damage is from the
"flooding" of the engine. More accurately this is too much
fuel inside the engines crankcase and causing a hydraulic
lock of the piston. The piston rises to the top of the
combustion chamber and instead of compressing gas i.e.
Fuelair mixture, it has to try and compress a liquid, fuel
only, which isn't possible. This puts a massive strain on
the piston, con rod and crankshaft. Invariably one component
will fail, usually the con rod causing massive damage to the
engines internals. To avoid flooding the engine, always start
the engine from cold using the methods mentioned above
and if at any time the engine becomes difficult to turn over
with the pull starter, then remove the glow plug and empty
all excess fuel out of the head and start again. The pull starter
can only be damaged by a flooded engine or by pulling it out
past its full length, so if you break a pull starter, this is a warning that you are flooding the engine, or pulling it to far be warned.
Important If you have purchased or are thinking of purchasing a ready to run
Nitro car please note:
You should check tighten all screws, nuts and bolts before use and
as with all Nitro cars it if a good idea to also check them at regular intervals.It is also a wise precaution to use a thread lock adhesive on
metal to metal nuts and bolts, this will help to stop them loosening
(as vibration can cause them to come lose).
If you follow these simple precautions you should prolong your pleasure with these products.
These hints are from my LHS web page (Old Town Models)
and i hope they help you out as they did for me to run in you
new nitro engine.
Colin
Sounds good to me, that lot.
The only thing i would add to that for newbies, is that when fine tuning your engine, remember that they are primarily liquid cooled (fuel), not air cooled. So be careful not to lean her out too much! It might seem like you have the right settings, cos she's 'going like a rocket'. But there's a fine ballance between 'well tuned', and running too lean.
BTW, I think a nitro thread is a good idea [:)]. All the info you need about RC cars all from one forum has got to be good.
You know you're running TOO LEAN when:-
1) the glowplug is glowing red... on the OUTSIDE
2) the glowplug falls out... and the engine is still running!
3) your piston & sleeve become nicely 'anodised' blue
4) the plastic parts on your carb start melting
5) the lexan around your engine start melting
6) the silicone exhaust coupler melts
[:D][:D]
and not forgetting to get as much fuel fumes in your face as possible, just so you make sure you can't breath or see.[;)][:D]
And always decant your fuel into a sodapop bottle, and put it exactly where you'll grab for a swig when thirsty... [}:)][}:)][}:)]
