Push it faster???!![:o)]
You could change the gearing. Or get an 8.4 volt battery, but that would reduce the motor life in the long run
very marginal. There is alot of friction if using the plastic bushes. Bearings get rid of most of it. To be honest there are alot of good "stock" motors out there that are far faster than a standard 540(if thats what your using). Even the 540 sport tuned is an improvement, and you wont have to pay modified motor prices
If the car was bought new, and is the TT01 chassis, the motor should be a plain silver can motor (stock 540)these have rpm of about 14-15k. Alot of good "stock" motors are now running at 20k and upwards. This equates to higher speed.
thanks , i gonna justbuy sum bearings and a faster motor and get
my uncle to do it for me lol , i dunno much about them.. i got him to make it [:P]
k now lemme make this a bit more understandable, i aint got a clue about which parts are good and what isnt ... i wanna know what will make it faster than it is at the moment, hopefully much much faster.
i got..
Chassis Type: TT-01
Scale: 1/10
Length: 17.36 inches (441mm)
Width: 7.28 inches (185mm)
Wheelbase: 10.12 inches (257mm)
Front Tread: 6.18 inches (157mm)
Rear Tread: 6.18 inches (157mm)
Weight: 3.46 lbs. (1570g)
Chassis: ABS Tub
Suspension: 4 Wheel Independent
Damper Type: Plastic coil over friction
Drive Train: Shaft drive
Gear Ratio: 8.35:1
Differential Type: Bevel Gear
Engine: Electric 540
Speed Controller: Electronic Speed Controller (CPR Unit)
Wheels & Tires: 10 Spoke/Radial
Body Type: Polycarbonate Cut & Printed
Caster Angle-F/R: 2deg/0deg
Camber Angle-F/R: 1deg/1deg
Toe Angle-F/R: 0deg/0deg
Differential Gear System: F/R 3-Bevel Diff
Tire Width: F/R both 27mm
Tire Diameter: F/R both 65mm
Tread Pattern: F/R Radial Type
Radio: 2-Channel Pistol (included)
Power Source: 7.2V battery (not included)
i duno what half that stuff is lol
CPR Unit is installed?? Not the 3 speed friction speed control??
What radio gear are you using??
Weight can make a difference, but not enough. The best way to get more speed would be a better motor. You cant beat more RPMs. Saving weight will end up costing more in the end, and will not gain much speed. It may help handling though.
If you do upgrade the motor, you will need bearings and electronic speed control. As you can see the £'s will add up.
im gunna buy a new motor then, which type u think would work best.. as i said, i aint got a clue lol..
and i have bearings but they are plastic.. and that stuff u named at the top.. i dunno what that is too lol [:I]
Any chance you can get a photo on your showroom. Maybe include 1 of the speed controller. If you go for a modified motor, it is important to get the bearings in first, or you will get wear very quickly. If you have the standard kit speed control, that would not handle a modified motor either. Electronic speed controllers are rated to number of turns a motor is. The lower the turn, the faster(usually), but also the spped control has to handle more current so costs more.
If you look on the box, does it say "includes 3 step speed control". If so, this is a manual speed control, not electronic, and will not handle todays modified motors
it says.. A 3-STEP FORWARC & REVERSE SPEED CONTROL IS INCLUDED,
on the side of the box it says i can get a RS-540 SPORT-TUNED MOTOR can tune it up
Sport tuned is a Tamiya hop up motor. Cant remember the specs. Guessing at around 18-19k rpm. Is a cheap upgrade, and will work with the mechanical speed control you have. A fast modified motor isnt suitable with the speed control that came with the kit. If you read some of the other posts you will see lots of comments about getting bearings and ESC first.
  • 1 year later...
my tt01 is running;-
fuly ball raced
ripmax unlimited esc
super stock RZ
everything else standard, and you wont beleive the difference.
it does help if you build your models as then you knw which bit is which, i can remember building my first tt01 it was a bit of a mare but i got there and i'm pretty up on it now.
