HELP!! I have just cleaned my bros nikko r/c car after he had driven it round the garden, and when i turned round he was spraying it with the hose!! So now when i connect the battery to the car the wheels just spin and are uncontrolable. I reckon he has soaked the motor in water becuase the motor is encased and sealed apart from a small breathing hole! So i cant take it apart to get to the motor and it seems swamped. Any suggestions as to how i can dry it out short of using a hair dryer!!
Justin
Let the whole car and motor AIR DRY for a few days. Do not dry it with a hair dryer, you can cause more damage.
If this doesn't work, then its knackered.
James
B)
he's right, so we strapped some coke bottles to it and put in his pond, then we took the tops off the bottles and it sank!
id="quote">id="quote">
that is true[:(] i've got a wild dagger now and i'm not doing the same to that[:(!]
quote:that is true i've got a wild dagger now and i'm not doing the same to that
you're not, but i might, when you have your back turned[:D][:D][:D][:D][:D]
