Hey guys, feel a bit stupid asking this [:I] but how does breaking work on an RC car with an ESC?? lol
Justin
Electric motors turn when you apply power, but they also act
like generators - they provide power if you turn them.
The ESC simply shorts the motor out... if the motor is turning
then the "back EMF" generated will act against the revolution
and the motor stops turning.
The energy is dissipated as heat in the motor, circuit &
ESC's brake FETs.
What about those ESC's that put the power 'gained' by braking (partially) back to the battery pack? Does that really exist, and will it increase runtime? Or is the ammount gained so low that it's insignificant? [?]
If they really do so, runtime increase won't be insignificant at moderate braking, but think you can achive hard braking only by wasting the energy at the ESC.
Guys, I noticed in all the testing I've been doing that using a smaller pinion also helps braking. I'm not sure why but the same ESC will brake much more effectively with a much smaller pinion. Could this be that the gearing is acting as a brake? ie. small pinion makes it easier for motor to turn wheels but makes it harder for wheels to turn motor? so under no power the wheels have to slow down as they can't turn the motor as easily as if larger pinion fitted? I confess I have no idea of what is happening other than it seems to work like that?!*
id="quote">id="quote">
with a smaller pinion gear the motor has to turn more often to turn the wheels, so if the motor is turning more often the effect of it acting as a break would be greater,
maybe [:o)]
i just had a little think, now if the motor is turning faster because it has a smaller pinion, it will be generating more power when the car is rolling, so when its shorted it will be generating more power to cause a more powerful breaking affect.
ive never heard the theory on this breaking feature before so i really dont have a clue what im talking about!!!! [8D]
I came to this conclusion when braking was discussed in this thread:
http://www.tamiyaclub.com/xforum/topic.asp?TOPIC_ID=11026
and Theo confirmed it. Great minds think alike [;)][;)]
yay [:D]
i thought that made sence when i wrote it, but its nice to see you guys put into into proper terms!
i tell you whats the best for of breaking thow, (well at least it looked cool [:P]) ---
it was these big 1/6 scale nitro buggies with front and back disc breaks on each wheel,
they looked so cool[:P]
well i havent got an esc, but if i'm running my pumpkin and i need to slow down, i just slam it into reverse [:)]
clod buster doesnt like that much though because it ends up on its nose!
i'm just about to go offline but this is going to bug me!
EMF stand for electro magnetic field rite [?] [:P]
Electro Magnetic Force rather than field. It is measured in volts.
Found this while I was digging around - useful stuff if you can wade through it... [xx(]
http://www.alansmodels.com/links/tom_younger/motortech.htm
cool, force - that make sence [:D]
