[:)]id="blue">Hi all.
i have a new hornet i have just built and enjoying very much (first rc)a mate has given me a tamiya sport tuned motor part number ta53068. will this be ok to fit straight on to my hornet with no other mods and will it make much difference to performance????
[;)]thanks again all.
Would be a good idea to get a set of ball bearings for the car if you haven't already. Will give you a good speed increase, and reduce wear. You'll need 9x 1150 and 1x 850.
- James
Yes, HunterZero has a good point - although saying that the Hornet box is simple enough that you would get away with the sport tune without the bearings... you would be getting a longer run time and less wear in the long run with them fitted.
[:D] Thanks all. ive already got some bearings so thats good.
going home to isle of wight this weekend so ill test her there.
Just a pointer: Test her before you go, else you could have a problem if you get there and realise that you've forgotten to solder something lol
HTH
Sam
HTH
Sam
id="quote">id="quote">
[;)]Good point.
