Hi,
I bought a Rising Storm this week end and i need accesories, but i don't know which charger and battery i must use.
Some advices please ?
Get yourself a 3300 NiMh battery (approx £25) pack (GP or Sanyo cells) for decent run time, and get a peak detection battery charger (at least £20, probably more) that can charge NiMh packs. That's the minimum you should spend probably. If you want to do anything more than bashing around, you probably have to spend a bit more...
get some sanyo 3000's they only cost me 40cnd. and when i made the swich to the sanyo's there was a definate performance boost. also sanyo's have a 20amp discharge rate, vs. 30 which is in most battery packs.
Sanyo 3000s don't have much punch, better get GP 3300s. The discharge rate is just the rate manufacturers do their capacity measurements and has nothing to do with the battery, the current depends mainly on the consumer (ESC and motor).
