i`m in need of some help with my top force.
it`s currently running an integy jett v8 12x3 with 18t pinion, an ancient tekin no limit esc and a cheap 3000mah nimh pack.
top end is good but acceleration is poor (jutts off the mark).
my question is:
is this motor suitable for the top force or should i get a different one, or is the ancient esc or cheapy battery to fault?
any suggestions on the best set ups for this car would be greatly appreciated.
As HunterZero said, Is anything getting excessively hot, that is the ESC, Motor or battery. If all 3 are getting really hot, try putting a smaller pinion on the motor eg. 16 tooth. This will improve the acceleration of the car, but you may have a lower top speed.
If nothing seems to be getting Hot, then try a different (better quality) battery, as this would be my guess as the cause of your problems.
yes it does get a bit on the hot side, thanks for the suggestions i`ll try out the 16t pinion and if that fails the battery too.
