Getting back into racing, and need some help setting up my car.
What I'll be running:
Schumacher Mission S1
Orion Core motor
Schumacher Mini Pin yellows
LRP Runner plus ESC
Cheap ACOMS servo
Standard ACOMS Receiver
Mini-T transmitter
The track is a polished wooden floor track, with only one straight, of maybe 10 metres at most.
Tricky and twisty, so accelleration is more important than top speed.
I'm going to be using the 17T belt gear (or whatever it's called [:)])
Cheers.
Sam
Cheers Terry - I will
quote:Originally posted by terry.sc
Best advice is to ask the other racers for their setups, especially gear ratios.
id="quote">id="quote">
I believe this is what I'm doing [?]
I meant at the track you are racing at. I could give you an idea of gear ratios for my clubs track as it is small as well, but we race on carpet so the ratios we use will not help you. It's been about 20 years since I raced on polished wood so I can't help on setup. For gearing if you don't know where to start use a small pinion and work your way up, it's better for your motor to be undergeared rather than overgeared.
