Roughly how many different TB01's are there?
I'm not talking about bodyshells, but differences in the chassis;
First one I bought was bushed, except for the diffs, 1/2 bushes 1/2 bearings
Second one, bearings throughout
Third one, no lexan electrics cover or drivers but it had an alu driveshaft
Also the Enzo TB01 comes with a foam bumper!
Are these changes permanent alterations to the predecessor, or does it depend on the car?
It depends on the model.
First lot (German Subaru, Evo VI):- had 2 BBs only, cast-metal diff gears, steel shaft, 16t pinion.
Some later ones (Suby Proto, Focus):- had full BBs (noted on box)
Only the rally ones have the chassis cover with the 2 heads.
1st Road TB (NSX2000):- had 4 BBs, plastic diff gears, ally shaft, 19t pinion.
2nd Road (Enzo):- has that huge front bumper, full BBs? Rear track wider?
