quote:
Originally posted by fury_dice
Found these links:
This one quotes TT01 at 8.35:1
and the TL01 at 7.96:1
Is that what you were after?
HTH
David
id="quote">id="quote">
David:- thanks, but yes & no.
Would also be a help to know what pinion comes in the kit to give
that ratio... hmm, no one's scanned in a TT01 manual for TC yet. [B)]
  • 3 years later...
Anybody know the Internal Gearing Ratios for the TT01?
Also the TL01?
thanks!!
The internal gear ratio on the TT01 is 2.6:1, the same as the TB02.
TB02/TB02R & TT01R 06 Module Gears (Internal Ratio = 2.6)
Motor Mount Hole
A
B
C
D
A
B
C
D
A
Spur Gear
61T
58T
55T
Pinion Gear
19T
20T
21T
22T
22T
23T
24T
25T
25T
Gear Ratio
8.35
7.93
7.55
7.21
6.85
6.56
6.28
6.03
5.72
TT01 06 Module 61T Spur Gear(Internal Ratio = 2.6)
Motor Mount Hole
A
B
C
D
Pinion Gear
19T
20T
21T
22T
Gear Ratio
8.35
7.93
7.55
7.21
Internal gear ratio of the TL01 depends whether or not you have Speed Tuned gears fitted
TL01 06 Module Gears
Gear Type
Standard 50738 (Internal Ratio = 3.87)
Speed Tuned 53342 (Internal Ratio = 2.9)
Pinion Gear
19T
21T
23T
19T
21T
23T
Gear Ratio
7.96
7.20
6.57
5.95
5.39
4.92
HTH
