Wanted for Monster Beetle
Headcase
Hi Rick
If you mean the servo saver (K5 in the manual I think) then you should be able to use a variety of bits including the standard Tamiya part (50204 - worked OK on my Frog) and the hi-torque equivalent (50473). Make sure that you can get the ball joints to fit. Otherwise there are third-party servo savers from people like Kimborough that your LHS will probably stock. Maybe take the broken one in with you to check? HTH. David
