Where are the blue dampers? [:P]
I think that looks **** nice, for a touring car. I can already see a version with more plastic comming: the TA-05.
Though one thing my eagle eye is missing: The holes for the racing front hub carrier (as on TA-04) are there, but there is not actual rods... Also the steering rods are on ballheads that double as the upright pin.
The holes are on the front C hub next to the ballhead of the steering rod, and the rod should go to a ballhead which replaces the 2 screws (left and right) in the upperdeck that are right above the steering arms.
But you can always buy a hop-up perhaps. [}:)]
But the extra front suspension braces are undesirable anyway. At best they just add a little friction, at worst they hold the suspension out of place after a crash.
quote:
id="quote">id="quote">
The C-carriers with the hole are different in camber
to the stock TA04 item without the extra holes...
Same deal as on the EvoIII.
Desirability of the torquerods differs according to your preferences.
Setup as per Tamiya instructions, they will do funny things to your
camber as the suspension moves up. But this can be adjusted by
shimming one pair of balls higher.
I feel the rods make the TA04 livelier and corners better
(or might just be the camber change??). Have put rods also
on EvoIII and there's less "improvement", but it does
stiffen up the slop a bit.
Local race guys think the rods are just one more thing that
can fall off in battle, but personally my impacts have popped
off more rear links than any front ones. By the time its popped
the front link/s the susp arm (hard) would have broken and
the hingepin needing replacement.
Mega hint:- if anybody wants to put torque rods on TA04/EvoIII
and you don't need fancy titanium etc turnbuckles, just buy the
53300 TL-01 turnbuckle tie-rod set, gives you all you need - cheap!
(if TA04 hasn't got the new C-carriers, buy
53458 TA04 Racing hub carrier set)
Willy, on your pics is has blue dampers (and a black spurgear too). I't doesn't make me feel blue though I like the silver dampers on the car better. [8D]
quote:
Originally posted by Porsche 928_gts_02
Anyone know where I can purchase this car? Done a search for TRF 415 and NOTHING shows up...
Patience patience... its still very much a preview/concept vehicle
imho. Has not even been announced on Tamiya's website yet.
It will probably be debuted by Surikarn in Thailand this weekend
but it'll be months away at least before it reaches any shop shelf.
quote:
Originally posted by malcolm
Wonder why they did another belt drive car, after the EVO3 was so successfull?[?]
HPI Pro I/II
AE TC3
and now...
Corally Assassin!
[:D][:D]
I think Willy was referring to the "myth" that Tamiya copied the HPI pro witht he 414 - and the TC3 with the Evo........
Trouble is with these sort of theories - is that if you want to get real technical - have a look at the first "REAL" racing orientad touring car - the Yokomo YR-4....hmmmmmmm - all designs are an extension of that if you look..Also - you could even say the Tenth Technology predator is a benchmark for shaft drives.............I seem to remember team associated drivers using them at several major meetings before Associated "designed" the TC3.........ahhhh - but I am being to "historical" now........
Darryn
LOLOL
With my comment on the Yokomo YR-4 - I was more talking about touring cars.......have a look at the layout.....remarkably similar when you take away some of the "bulk".......
Darryn
quote:
Originally posted by tony gray
TB01 Evo 1 Pre-dated TC3 by a good 12 months or so.
what calender is that on ? care to share the dates ?
