ARTR Clod crawlers
2 For sale, £300 each, no trades please
Both rebuilt using used tires, gearboxes and wheels, all stripped down and cleaned.
Anything that needed to be replaced has been
Diffs are locked and full set of bearings fitted in place of kit bushes
Chassis is a 3 off custom job
DuBro ball ends used throughout, even on steering rods
GMade top link mounts
alu axle bracing
Associated battery cups
Steel pinions on standard 540 motors (not fitted yet, but will be)
Wiring harness for parallel motors also included, and fitted if required
INET wheel wideners fitted
Custom lo-profile servo mounts fitted, necessary axle tube mods done
Critical dimensions;
Wheelbase 14¾'' / 370mm
Width 17'' / 430mm to outside of tires
Clearance 5½'' / 140mm under centre
Apart from motors, no electrics are included
Please email me if you want more picturesid="red">
