I've just bought a pack of 6 nimh cells along with dean connectors to replace the tamiya ones, and had the cells assembled into stick pack but i will need to atatch the deanes clips onto the wire coming from my ESC which currently has a tamiya plug and connectors. Do i 'pull' the wires out of the plug, or cut them, im not sure what i have to do. [8)]
Did you just cut plug off??
If your wanting to take out the pins, there are 2 very small clips on each pin on the part that plugs into the female connector. You will prob need a jewellers screwdriver to push the pins in. It wont be easy either. As was mentioned before, just cut whole thing off and solder to the wire.
