Hi, I have a TT01 and I'm gunna need to buy the metal motor mount hop up for the p2k2 stock motor i've just bought! so with a 12 turn, theres a small chance it could melt... [8)]
I would recommend upgrading the plastic motor mount and prop.shaft to the aluminium ones when upgrading your motor as the plastic shaft deforms at higher speeds, and hits the chassis. Also get the heatsink for the motor [;)]
Chris
i already have a ball bearing set and a 23 turn pinion gear but i might get the metal motor mount as i don't want it to melt[:(]
Hi I have race bearings and looking to order aluminium prop shaft, motor mount, and heat sink. The next thing I'll upgrade will probably be the shocks, but im not sure whether to get the cheaper CVAa or 'invest' in some aluminium low frictions...hmmmm
Chris [:D]
