how much u think each of this stuff will cost in £..
ITEM 53068 ... RS-540 SPORT TUNED MOTOR
ITEM 53497 ... TT-01 BALL BEARING SET
ITEM 53620 ... ALUMINUM PROPELLER SHAFT
thanks
thanks
id="quote">id="quote">
Hi there, I have the bearing set, bought them from timetunnelmodels (http://www.goldstarstockists.com The aluminium prop shaft hasnt been released in the UK yet as i tried to get it from there aswell [8)].
looking at the shop on the above address, these are the prices
ITEM 53068 ... RS-540 SPORT TUNED MOTOR - £21.50
ITEM 53497 ... TT-01 BALL BEARING SET (TT01 XB Pro Ball Bearing Set (Official) - £19.99
And the aluminium shaft is £6.50 but not here yet
So youre looking at just under £50
hope that helps,
Chris [:D]
Hi, if you're upgrading the motor i would suggest you upgrade the prop shaft aswell cos when using a higher grade motor, the shaft starts to deform at higher speeds. i've just upgraded my motor, and the plastic prop shaft hits against the chassis when running at top speed!! [8)][8)]
Chris
