Hi was wondering if any other make of rc cars does body shells that will fit my TT01 as I was told other makes like HPI and losi etc have more 'crash forgiving' shells and are often a lot cheaper.
Such as this HPI bodyshell - 200mm, il ahve to check the length of mine. 7431.jpg
HP7431
HPI
MITSUBISHI ECLIPSE 200MM BODY
Supplied clear
I dont get the 200mm measurement? [?] what bit is measured?
Thanks [;)]
Chris
These protoform shells say "Made to fit all popular 190mm sedans, it also meets all ROAR, BRCA and EFRA specs. "
Would they be ok? i take it you drill your own holes according to your chassis.
Chris
I quite like this one, I hope this fits alright.
All they say is fits 190mm [?] what if it dont fit the wheels or something. I think ill have a look in my LHS cause i think he has some there, see if they fit.
Chris
Chris
id="quote">id="quote">
Yep. Width is the only consideration, some rally cars, but not Tamiyas, are 200mm wide. Any 190mm body will fit any Tamiya electric touring car. On most bodies the rear wheelarches are not marked so the body fits any wheelbase. Just use the spare plastic cut from the front wheel arch as a template for the rear. HPI bodies have marks for mounting the bodies in the same position as Tamiya ones, although I'm not sure if the newer ones do that.
Proline bodies are designed for racing, so although they do not have the detail of a Tamiya they produce a lot of downforce for extra grip.
thanks terry [;)]
the only thing now is deciding which one of those nice shells to buy! [:D][|)]
Chris
You and me both [;)]
hey heres a list of tamiya parts on my tt-01
tamiya tt-01 spur gear set with diff pinions
tamiya alumium drive shaft
tamiya heat sink
tamiya tt-01 metal motor mount
tamiya tt-01 ball bearings
tamiya tt-01 front-way
tamiya ball diff (rear)
tamiya racing steering set
tamiya carbon upper frame
tamiya trf blue damper set
tamiya clamp type wheel hub (blue aluminum)
tamiya tuned springs
tamiya titanium screws all around
futaba radio and mc330cr esc
speed gem 14t double
trinity sanyo 2400 racing pack
tamiya 5mm blue ball connector
tamiya accord vtec rims
hpi advan tires
tamiya 03 subaru wrx body with carbon wing
and some more little things
190mm / 200mm is measured across the tops of the bonnet wheelwells.
Tamiya tourers usually measure about 182-186mm across the tops of the
front wheels (std wheel offsets), so you need a bodyshell of 190mm.
Tamiya's TG10 gas car also uses the same 190mm bodyshells...
but other's gas touring cars are wider and need the 200mm shells.
Thanks WIllychang. I'll prob go for a HPI or a protofrom, its hard to choose, ill prob end up smashin it up anyway, but thats beside the point...[8D]
lol
due to our LHS ppl, wont get off there lazy AZZZ!!(can i say that??)
we dont have any HPI stuff at all, cant even order it, so we miss out on the real nice HPI bodies[:(][:(][:(]
though ive heard its pretty hard to get HPI stuff across aus, is this right Mr willy??....
Dan
Nup, I wouldn't put many options into a TL01/TT01 as it'll be a
waste of $$$ - much better off saving it towards your next car.
Ballbearings would be the max I'd go, if I had to run one.
I've done some re-engineering but... eg DIY ally shafts, improved MSC.
My usual ride is TA04 or TBe3.
TL01/FF02 chassis only good for displaying shells on the shelf imho. [|)][|)]
I plan ahead... a TL01/TT01 fully-kitted with all the fancy goodies
will have costed you *more* than a fancy limited edition Tamiya, yet
will be worth much less if you ever try and resell it later.
What's the logic in that?
though its up to parts avalabilty aswell....i know our LHS dont stock any TAMIYA parts from the odd skrew and ball bearings.....and a sport motor, lol....
but on the other hand they have loads of kyosho alpha parts, thats why there are quite a few off ppl with them cars...
i like the TL01 chassis, and i like the TA03R aswell, but i dont see the point off buying a EVO3SL when the racing is not good down here??....and id probably end up busting it anyway..
Dan
Its no secret, don't like the current HPI importers.
Didn't like the last ones before them too - beyond hopeless.
Why can't we just get someone that DOES THEIR JOB??! [:(!]
I keep watch on HPI's website too, and they're pretty tasty there.
Some HPI shells are available... sporadically. Not cheapest on the
market though & there's some very interesting ones available.
Metro usually has some, so does Mack's - usually ~A$50ish.
Hate their pre-cut stickers though. (Are ppl all that lazy today?)
btw don't blame the LHS. Bodyshells are bulky lightweight items
that are best shipped via sea in containers for economic reasons.
So all our bodyshells have to come from the official distributor/s.
Last couple of years the AUD has been pretty low against USD too,
only lately its improved quite a bit - HPI is Californian.
new i could rely on you Mr willy for the answer...thanks...
so its the importers than, not the lazy guy at shop??...though he is pretty handy, had a reciver ordered in on the thursday, got it the next day[xx(][xx(]
then again i order some other stuff, and had to wait 2 weeks..
ohwell....
Chris Uk, could always by anoughter tamiya body, you do know they make the best bodies..
Dan
Which LHS do you go to, Dan?
Thought it was either Hoppers, Mack's or Metro.
Can't complain with Metro, they're as good as any. Have been up to
ACT, NSW & QLD shops and they're all pretty lame comparatively.
quote:i like the TL01 chassis, and i like the TA03R aswell, but i dont see the point off buying a EVO3SL when the racing is not good down here??....and id probably end up busting it anyway..
Racing at TFTR (Templestowe) is world class. Permanent tarmac
dedicated electric track, large & challenging layout.
Not even the Sydney-siders have anything like that!! [:P]
I thought all that red alloy was pretty poofy... but trust me,
it GROWs on ya! [;)][|)][:D]
ohwell....
Crashcourse in stock-handling @ LHS Danny.. [:D]
They just note down what you want (part # etc), add it to their
order list. They might order monthly/fortnightly/weekly.
If the part is in stock at Sydney then sure, it arrives in the next
shipment. If not, then its backordered until it turns up in the next
container from Japan. Might get a container in every 2-4 wks.
Add all that time up, you'll soon see why you could be waiting
either 2 days or 2 months depending on the stock situation & where.
well im from launceston, so there is only one good hobby store here, tigermodels...prety lame, but can have nearly any tamiya parts ordered....even some older bits...
but parts on stock is ****....its a hobby store with trains, model cars, boats, etc, not really a RC store, but more ppl are getting into it...
EVO 3 SL, yes the red bits look nice, but i would like to see them blue[;)]...me TA03R will do for a while,
Dan
Sorry Dan (TASSIE!), got ya mixed up as a Victorian. [:)]
Yeah, things are pretty dismal in Tas, sorry.
Why don't you rev things up a bit by organising something yourself?
yes, tassie..lol..
organise me self??...me??, at 17, who is going to listen, i hardly know any one down here with cars, yeah there is a nitro club, but they all stuck up, hahaha electric sucks.....[:(!]..
and i know there is a smaller electric club, will have to go check it out......
Dan
