i,m using a futaba magnum junior transmitter on both my mardave and another optima that i,ve re-built. my question is - on the right hand side face of the transmitter, there are 2 adjustable screws - (throt A.V - high/low) - what exactly do these switches do?, and is there anything i should know about these switches when setting up an ESC?.
any advice greatly appreciated [;)].
james.
Hi James
I have one of those - the pots are to set the 'end points' on the throttle channel, i.e. max forward and max reverse. I guess it's if some sort of servo-operated throttle (like an MSC) travels further in one direction than the other.
I have only used them with an ESC when I wanted to limit the max speed for the nippers to drive. I set the ESC's up with these maxed, as you fix the end-points on the ESC itself during the setup process.
I'll double check on the actual unit tonight and amend this post if necessary. HTH. David
ah,ha.....that might explain why the throttle servo on my mardave (nitro) packed-up - it seemed as though the motor was burn out?. i had the servo set up so it only worked in one direction, but the weird thing was - and i,m not sure how to explain what was happening - but if the servo was operated to maximum throttle, if i adjusted one of the screws on the right hand side, the servo automatically went back to neutral - while the throttle trigger was held full on [8)]????. there,s also a throttle trim button on the left hand side, but i keep that set at zero. i think (hope..) i,ve finally set the mardave up ok, but i,ve fitted an ESC on the optima and i dont particularly want to burn that out with incorrect settings.....[xx(].
great transmitters - they,ve just got more buttons than i,m used too...[:I].
james.
Hi,
Use a 3PDF that also has ATV settings although as the radio is a computer set they are digital. The ATV is designed to limit how far the servo moves and designed to overcome limitations in mechnical adjustment. For example:
Full steering lock is reached at aprox 75% of maximum servo travel, but it trys to move the other 25% and you end up with something along the lines of the unmovable object against the un-stopable force.
By setting the ATV you effectivly tell the TX "when i input 100% travel i want you to send only 75%" and the servo stop moving just before or dead on full steering lock. Hope this makes some sense as i've done a pretty poor job of explaining things, lol!
