I can't remember what the internal gearbox ratio is on a B2 (it might be 2.4:1) but for the 15 turn I'd use a 22 tooth pinion and go from there. For the 17 turn start with a 24 tooth pinion.
These are conservative ratios, you can probably gear up 1 or 2 pinions if you've got good cells.
