Been after one a while and now I finally have one I can't figure out how to get a servo in it! Any info on the car or some scans of the manual would be very handy.
1. Remove top plate.
2. Remove ears from servo.
3. Place double-sided servo tape on chassis.
4. Stick servo to chassis.
5. Bolt top plate back in place, holding servo in situ.
Simple.
Should probably have just left the servo there... [:I]
Alex
Just make sure the servo is centred correctly with the steering links on the servo saver (I recommend a large Kimbrough servo saver) and test fit to make sure there is clearance before sticking the servo down. My Xpress needed the servo slot in top deck filing backwards a couple of millimetres so the steering cleared the gearbox.
