I have a Nitro car and I run it up and down the sea front raceing am useing Duracell Ultra M3 at the moment but its costing me link £20 a set
I have been looking at geting 2 set of Rechargeable batteries but dont know which type any one help me out?
Glow plug heater
Duracell C Ni-MH Rechargeable 2,200mAh
Uniross C Ni-MH Rechargeable 2,00mAh
Car and Control
Uniross super high capacity which are 2,000mAh
Uniross ultra high capacity which are 2,300mAh
Also which charger you think is best
stander or fast?
Also if anyone know where I can get cheap batterys from like I have said then please let me know.
[B)]At the cost over £90 a set which ever type I go for
NEVER use loose rechargeables inside your Nitro RC car!
with Drycells... 4x 1.5V = 6V.
With rechargeables... they only have 1.2V... 4x 1.2 = 4.8V.
Your servos will have less energy & speed.
If you want to replace your 4xAAs, best to buy a rechargeable receiver battery pack which contains FIVE cells (5x 1.2 = 6V).
You can also buy rechargeable battery packs for most TXes.
A soldered pack is better than loose cells.
Most TXes also have ability to charge the battery pack in-situ,
if you buy the correct charger/connector for the TX's jack.
