hello all!  I'm hoping someone can help point me in the right
direction.  I just got ANOTHER Super Blackfoot off of ebay.
At first it looked like it was RTR.  But, then when I took apart
the gearbox to add ball bearings to it (instead of the plastic
bushings) I found that the bevel gears in it had grinded away their
supports that hold them in place. So, does anyone know of a better
solution to the stock differential gear?  will the ball bearing
gear for the M03 work?
http://www2.towerhobbies.com/cgi-bin/wti00...=LXGE35&P=M
thank you for your help in advance!
Hmmm... that's good question!
I have a Manta/TA ball diff here, so I might tear down my KBF to see if
it's a fit.  Unless someone else has already tried and
failed?  I know that it uses the standard cups, but the diff gear
might be a different size or 'offset'.  Would love to know if it
works: A Blackfoot with a ball diff is a good thing!
(If I don't see a definative answer here soon, I'll get that KBF on my bench and let you know!)
OCD... thank you, thank you, thank you!!!
I've already ordered a set of bevel gears from Tamiya. But, looking at
the design with the metal bevel gears spinning on the stationary tiny
metal shaft. To me it's just a matter of time before it grinds through
the new replacements as well...
So I did a complete tear down on my King Blackfoot this evening.
I'm not sure if the Super BF is anything like the KBF, but a Manta ball
diff will NOT fit in place of the stock gear.  The stock gear
(much as I expected) is about 10 teeth taller than the ball diff
gear.  On the bright side, all the internals are standard fare, so
they are quite easy to obtain. When I rebuilt mine, I replaced the diff
cups with TA03 pieces I had in my toolbox.  I also replaced the
dogbones with TGX pieces that are identical in size/shape!  Like I
said, this is for the KBF, so I don't know if this applies to your
Super Blackfoot.
OCD thank you for trying. I really appreciate it.  The King
Blackfoot and the Super Blackfoot have identical gearboxes from what I
can tell.  So, I'm sure that it still won't fit in my gearbox
either. So, I guess I'll be rebuilding my differential with some stock
bevel gears. Unfortunately, everyone seems to be out of them at the
moment.  Any suggestions on how to best protect the bevel
gears?  I'm thinking that I put a buttload of grease all over the
metal pieces and then screw the differential closed...
No problem Jimbo.
I'm not sure what the problem is that you're having...  My outer
diff plates had some wear, but nothing that would effect
performance.  As far as I can tell, the diff uses standard tamiya
internals, so any of the bevel gears/plates/etc. should fit inside the
gear.
(If I'm wrong about this, somebody step in and let me know.)
As far as protecting the gears:  No use in loading up the grease;
most of it will be flung out the first time you hit the throttle.
What you'll end up with is a messy gearbox full of grease.  Just
use the kit supplied ceramic stuff in moderation and you should be
fine.  When I had a closer look, my diff was worn where the outer
plate contacted the outer bearing. Not bad enought to cause any
problems, but eventually I may add a shim on both sides to take up the
slack. These gearboxes really are one of Tamiya's better
designs.. dare I say nearly bullletproof?
Hello OCD, below is a picture of the bevel gears that I'm talking
about. it's the small support metal support that holds the bevel gear
that wore away on my Super Blackfoot. I know that eventually the gear
will wear away at the support.  But, I'm hoping that if I add some
extra grease in the differential case and then screw the differential
cover back on (the cover that covers the differential gears that it'll
keep enough of the grease in the differential to help prevent the
metals parts from wearing away at each other...
This might be one of those 'if it's not broken' type scenarios..Since
the bevel gears are nearly stationary most of the time?
Are the outer ring gears rubbing the bevel gear shafts?  If so, you might be
able to shim it from the inside.  I can't recommend it though, as
I think that the added friction my be no good here.  Have you
thought about using extra heavy grease to slow the diff down?  I
use this in all of my geared diffs.
actually that's the problem. it IS broken.  I got this truck off
of ebay a few weeks ago and it looked okay. but, when I was taking it
apart to put ball bearings in it I noticed that the previous owner ran
the thing til it almost fell apart. Some of the plastic bushings were
almost worn through. never seen that before.  then when I opened
up the differential to see if it was okay I noticed that two of the
bevel gears just popped out.  then I noticed a couple of "extra"
metal pieces.
As for thicker grease, that's what my plan was all along. BUT, what
grease do you recommend?  I've been using all-purpose lithium
grease that I got from a local automotive parts store.  Seems to
work pretty good on some other gears...
Ouch !
Now I get it- Those stupid bushings probably allowed enough play in the
axle cups to cause this kind of failure.  My guess is that once
you've replaced the bushings with bearings, that'll be the end of
that!
For grease I've been using a bottle of 10,000 weight I got from Tower
Hobbies.  It came with no lable on it, and looked completely
different than the picture on the website, so I have no idea what it
actually is[:$]
I've heard some people use friction damper grease that comes with some
of the Tamiya kits, but I'm not sure about this.  My TGR came with
a small pot of "AW Grease" for the diffs and it worked perfectly.
Unfortunately it was a very small pot, as I used every bit of it for
the two!
YES!  That's IT!
Well... I'm hoping that's the problem and that when I get the new gears
and rebuild the gearbox with metal bearings that it will fix this
problem. BUT, it would have been nice to have a ball bearing
differential in there!
I'll probably just stick with regular all purpose lithium automotive
grease for now.  It seems to have worked really well in my other
Blackfoots AND I can get a BIG can of it for cheap.
again thanks so much for the help!
