I have a couple of FF01 and TA02 chassis's and was looking to mount a 200mm HPI beetle body on them. Naturally the original wheels on the chassis will sit well inside the 200mm body. I think both the FF01 and TA02 have +2mm offset rims. Can anyone out there advise what rims I should be looking to use to get a better look i.e. +6mm rims or -2mm rims. (I think it is the earlier but before I look at purchasing rims I need some advice). I am also aware you can use wheel spacers which could pick up say1.0mm to 1.5mm on each side.
You could also use the long wheel axles and hexes , they give you 4mm extra per side. That combined with the Enzo wheels will make the car a total of 12 mm wider.
As stated and some more - to go wider
- Offset wheels
- Longer driveshafts (and a arms etc)
- spacer in the wheelhex itself
Jakes
