from what ive seen and heard the TB02 is a nifty basic kit,so apart from the usuall motor/esc/battery hop ups is there anything worth spending your money on for a furthur upgrade?any info appreciated.[?]
Hi
Plenty of hop-ups actually....[:)]
Evo 3 one way
Evo 3 lighten rear
Evo 3 aluminum upper mount
Evo 3 Front drive shaft
Evo 3 lighten rear driveshaft
Evo 3 Carbon damper stays
Evo 3 Aluminum racing steering rack
TRF dampers
TB02 stablizers
TB02 Aluminum motor mount (the Evo 3 ones are not going to fit.....)
TA04 harden uprights and arms (If not Evo 3 aluminum arm stays with toe in or out adjustments
Titan turn buckles for all arms except the steering ones
Aluminum wheel hub with lock.
SSG Carbon tub reinforcement plate
However after throwing all this in, you need to balance the total cost of the kit with hop ups against the Evo 3 kit if its still available where you are........[:D]
If you buy the EVO 3 upper and lower graphite decks, you should then be able to use the EVO 3 aluminium motor mount with them. Then your TB02 will be on its way to being a EVO 3 :)
Hi nick.....
I thought of it but its not that simple and you need to get the battery holder as well. On top of that, there are afew other bits where steering rack is and just after the spur gear, that needs modification before it can be completed.......
