Red anodized aluminum parts
Titan hex screws and titan turnbuckle shafts
Rubber sealed ball bearings
3 mm thick lower deck
Reinforced diff. joint with rear lightweight universal shafts
SOREX tires (36R)
Newly designed aluminum upper arm mount
Newly designed front/rear special damper stay
Newly designed carbon plate for one-way unit
Evo III special stickers
Guest Carsnboats
There is a write up on this car in Radio Race Car International magazine, October 2003. Haven't got a flatbed scanner or I could have copied it.
quote:Originally posted by madman
...new TB evo 3 shirikarn special edition
vs... the original?
id="quote">id="quote">
Technically, its not really a 'replacement'.
The original TBe3 is a "Tamiya Catalog" product, item #58299.
The Surikarn Limited is a TRF product, item #49283.
(A bit like how AMGs are sold in Merc dealerships?)
If you disregard the Red anodized aluminum parts ,
there's really not much difference in performance.
-TBe3 doesn't have any serious weight problem, and Ti will only
make your car underweight. Stock parts work perfectly fine.
-nice to have, great bearings... but if you're gunna degrease them
might as well just stick with the standard metal-sheilded fare.
Tamiya blueseals need less maintenance if untouched, that's all.
-original is 2.5mm; improvement is marginal.
-diff joint works fine, rear lightweight shafts might be the go.
-only useful if you use the tuning options that delivers, but
otherwise the shocktower mounts work just as well.
I think I've gotten the Ally mount a little bit bent after
ripping off a rear arm... haha, lucky it was a blue piece.
-different shock towers... different body post location at the back.
Pain if you run both cars.
-cheap option, you'd have bought it for your std car already.
Biggest disadvantage with the TBe3SL is that one CAN'T BUY RED SPARES.
Yeah, all the red bits in the kit are exclusive to the kit; any e3SL
that's being seriously used will eventually turn blue. [:I]
And someone mentioned that the Red also fades. [:0]
(I'm keeping a close eye on that!!)
