Get the lunch box, they are a lot of fun.  the Blackfoot extreme will be selling for a long time, get the Lunch box while you can.  You will kick your self later when you can't.
 I had to decide between those 2 trucks also, i picked the blackfoot, im glad i did, the lunchbox is good for doing wheelies though.  The blackfoot will also do wheelies if you go backwards first
I'd go for the Lunchbox every time. The shell is much better looking, it's more fun to drive and, as Shodog says, you won't be able to buy it for much longer.
Well, went ahead and backordered a Lunchbox from TowerHobbies. Thanks for the input. I am interested in running this ij the snow - is there anything I should/can do to protect the radio gear/electroniucs from moisture?
Balloons are the way to go cheap and available anywhere just seal the end with a tie wrap/cable tie and away you go !
