iv just bought a fusion 10 turn motor and for some reason when taking off from stand still the car drifts off to the left any one know the problem please let me know
Firstly, please don't post the same question in multiple threads, most
people check all the posts and are less inclined to answer the
question after reading it several times.
You have a 10 turn motor in a TT-01 shaft drive car. Due to the
transmission design with a powerful motor it will always pull to the
left under acceleration and right under braking. It is caused by the
motor trying to twist the car under hard acceleration. This happens in
all cars with a central driveshaft and longitudinal mounted motor, the
more expensive cars have had a lot of development work to reduce it to
a minimum but it is still there.
If you still want to use a 10 turn motor the only answer is get a belt drive car.
True Terry, a belt driven car will cope alot better, atleast the handling side of things!
Now, if the driveshaft were weighted to the EXACT weight of the armature, and rotating the other way, wouldn't this cancel it out?
i hjad the same problem on my hopped up tt01....it was running a reedy 7 x 2 motor
i managed to control the problem by fitting a ball dif a one dif in the front, tamiya universal shafts, alloy arms hub etc.....ok the problem was still there, but no where near the same amount, i never experienced the real drift again, as all the drive train was stiffer, also i ran the tb01 evo prop and evo alloy prop cups, carbon top chassis etc .....lot of money to spend, and to be fair, for the money i spent, i could of brought 2 trf 415 msx's lol
if u want real competive car, sell ya tt01 dont spend any more money on it, and save the parts money u would of spent on  it.
andy
Only if the motor is also parallel to the driveshaft and the moment of
intertia (not mass) of motor armature and pinion has the opposite ratio
as the pinion/spur gear ratio to the sum of inertia of the driveshaft
and the gears driven by it in longitudinal direction (bevel gears and
spur). For example if pinion/spur gear ratio is 1:3, the moment of
intertia of the driveshaft subsystem should be even 3 times higher then
the one of the motor subsystem. Rotating direction is fine as motor and
driveshaft always rotate in opposite directions but problem is that the
armature has already a very high moment of inertial (big mass
concentrated on a big outer radius) so by making the drifeshaft and
gears having sutiable intertia for it would make the transmission very
massive and "dull" in acceleration.
A couple of points. The axle doesn't rotate at the same speed as the
armature. Also one rotating mass is on the centreline of the chassis, the other one around 20mm off centre.
The problem isn't in the rotating mass ( although it
does have an effect) the bigger problem is depending on which way the
driveshaft rotates under acceleration the motor is trying to either
climb over the driveshaft or go under the driveshaft, dragging the
chassis with it.
Even if the rotational mass are identical (which it cannot be as
rotational speed is included in the equation) the only thing stopping
the car turning over is the suspension pushing back. When the car
accelerates the suspension on one side is loaded up more than the
other, which is why they head off in one direction and the other
direction when braking.
Terry, as I wrote in my above post the problem is actually them moment (torque) of inertia and it could be balanced if the moment of inertia of the driveshaft system would have an inertial moment of the opposite ratio, but that would make the transmission much too "heavy" and "lazy". Also a transmission with big moment of inertia makes the car unwilling to steer and handling weirdly, due to gyroscopic torques.
yep, u can get all technical etc, or maybe just some good quality take off cs 22 tyres and inserts will stop the drift????  just a thought
andy
gyroscopic torques.
The problem with balancing the moment of inertia is that although the
moment of inertia is fixed for any speed the torque to accelerate it is
relative to the angular velocity. yes, you could also add to the
transmission to balance it out but surely it would need to alter to
cope with the different loads at different speeds.
I still think more force twisting the chassis is generated by the motor
trying to dive under the driveshaft and loading up the suspension on
the left side of the car when accelerating rather than the moment of
inertia in the motor.
It also doesn't help that the chassis are inherently unbalanced with the battery down one side and everything else on the other.
  • 4 weeks later...
Just by a belt drive car and be done with it lol. I would recormend a TA05 as its a great drive, stock settings with some 50wt losi shock oil over teh kit standard gives a real easy and confidence inspiring drive and the ebay prices make it only about £20 more than the TT01. so go on make the jump get the merc one...
Club slot car racers started to encounter the torque reaction problem in the mid to late sixties as motor power started to get higher. It was solved by mounting the motor across the chassis, like a belt drive RC instead of inline like a TT. They also arranged the motor so that the torque reaction tries to hold the front of the car down on acceleration and the rear of the car down while braking.
Lap times tumbled!
I have a C2 Pro motorn (19 turns), Oil Shocks, aloy shaft, ball
bearing, and still it drifts to the left, My guess is that it's just a
design problem on the TT01, so as others have said, if U cant live with
the drift, get a belt driven.
