Folks - what's the best no limit ESC out there? I want one that, come what may, won't ever ever melt or melt the battery connector. I'd spend up to £80 i reckon, and would consider second hand through ebay. Currently running with a 7 turn motor in my TC3 hence the need for no limits...
many thanks in advance. happy Sunday
Melting battery connectors is bad, try changing to a no loss connector like deans, they will give quite a bit better performance plus more run time oh yeah and less fires[:D].
i'm also using a 7turn motor for the first time. so obviously that's adding to the "burning" problem. Thing is, I want to go fast, that's why I thought a no limit ESC would cope...
i have soldered these ones on to the motor and the ESC (before it melted) - from my local RC shop. just thin metal male and female parts. these not the best sort?
Are they made out of a similar material to the Tamiya connectors? If they are then they aren't up to the job either. Also, did you say your ESC melted as well? What make and model is it?
the motor/ESC connectors are the same as the Tamiya/ESC battery connectors, only without the plastic casing. They are thin metal and hook in to each other. about a quid a set. i soldered them on. all the wires are thick.
The ESC was a ripmax no limit...apparently.
I'm not a huge fan of the Ripmax ESC, I'd much rather have an LRP or Nosram item. They may be more money but they are a much higher quality product. If you are planning on keeping the 7 in the car or don't mind a bit of extra hassle when changing motors, I would direct solder for efficiency.
I have found power poles to be very gd. I they come apart no problems and easilt take high currents. just an idea. And I agree with Mr pushrod over esc's. Lrp ones are definately worth the money and AI set up is fantastic just plug and play. cheers Ryck
