It depends on the track and your driving style, I always prefer slightly more acceleration, but don't over do it with too small a pinion as the motor will over rev causing it to overheat.
The above advice is true, except for the bit about the overheating!
You WILL NOT overheat your motor by fitting a SMALLER pinion. The reverse is the case, a LARGER pinion may make your motor overheat.
Electric motors want to rev, let them do so. If you fit too small a pinion all you will lose is a little speed, if you fit too large a pinion there is a good chance that the motor might overheat, your runtime will go down, battery may overheat and so could the speed control.
Overgearing (too large pinion and/or too small spur) is the enemy of your car, unless you are doing some serious racing and are prepared to pay the price DON'T do it.
For a stock 27t motor you need a gear ratio of 6.5. to work this out you need to devide the spur pin size by the pinion gear and multiple by the internal gear ratio of your car!
All of this should be in the manual for the car.
With a 20T pinion you will get better acceleration at the expense of some top speed, you will also get better run time from a charge. To expand a little on my other post you may not get a higher top speed if, for example, you went to a 30T as the existing motor may not be able to "pull" the raised gearing. Also on a tight indoor race track a high top speed would be of little use!
If you are a beginner gear as low as you can, you'll enjoy the longer run time, learn how to drive and have less  costly accidents (due to the lower speeds). Another bonus is you don't need anything other than a smaller pinion to gear down, if you gear up chances are you will have to spend money upgrading things to cope!
I have done a lot of club racing along with both of my sons, and as soon as I thought they could handle more speed I provided it, the results for both of them first time I tried were SLOWER lap times! they couldn't handle the higher pace and crashed much more. Crashes were also harder and did more damage due to the greater speed. There is a saying " To finish first, first you must finish" very true with RC cars.
Slow and steady often does win the begginers class!
