hello i have only one little question.
do you thinks its possible to take f201 rear tires for mount on a f102 because i try to find slick not sponge  for rear
and i find nothing ;)
thanks for yours answer  or if you know where i can buy it
djdespe
It probably not  possible without fitting F201 wheels as well, which may may not fit!
However later F103 derivatives came with slick rubber (as opposed to sponge) tyres and suitable wheels. These will definately fit your F102, unfortunately I can't tell you the Tamiya part numbers, but almost certainly someone on here can help you with the numbers.
Hi, the F201 wheel doesnot fits F102/F103 axis at all.
However, recently Tamiya issued F103GT and should the spare is available, it'll be an easy
conversion to F102.
thanks for your answer i try to find this slick tires (f103gt).i try to find only 1 tiresfor rear in slick if you have one (used or not) mail me
thanks a lot
